Ancient Brit here residing in southern Spain.
mavicpilots.com
Since you live in Spain, there are specific laws and rules for you to follow, please check to ensure these are current.
ENAIRE es el gestor de navegación aérea de España, controlando más de 2 millones de kilómetros cuadrados de espacio aéreo.
www.enaire.es
This is the link the Full Spanish Drone Laws…
You chose to live there, so you've "chosen" to follow their laws. Google the area for drone clubs, check our member's map and look for fellow members and PM them. It's all on you, fly legal or not, but some locations look pretty dimly on scofflaws and drones have created a very dipole group of lovers and haters…
Good Luck, remember, if yu do not read Spanish or just technical (legalize) Spanish, copy the text and paste it into Google Translate. It's not perfect but pretty darn good… "¿entender?"
As a beginner, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
