Hello! New to forum and new to drones!
Nebraska, USA
Excited to get into the world of drones!
I am looking to get into doing drone videography and photography for weddings, businesses and real estate along with taking it out on the golf course to film for fun. I am currently torn between two two drones, Mavic air 2s or mini pro 3 for my first drone. (or if you all know of any better ones that would work I am all ears)
Biggest needs.
- I live in Nebraska where it can get really windy and very dry heat (100+) so a drone that could handle both
- Active tracking for when I golf
- Camera/video camera
- Easy to use and travel with
- Easy to fly around people (large outdoor weddings)
Would the mini pro 3 be able to handle all of these (even the heat) or is it worth spending more money and having the bigger drone to get the air 2s?
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum. In my opinion, you should start with mini 3 pro to familiarize yourself with controlling and shooting with a drone, as well as editing footages. Mini 3 pro should be able to handle most of your needs. If you happen to look for a case to store and carry mini 3 pro, check out our MM330 hard case. Have fun.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) at least until you get your Part 107 License if you go into business . You mentioned two Drones, the Air 2S and you are required to register that Drone. The Mini 3 will on have to be registered if you go into business…
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
You wrote that you wanted to get into videography and photography for weddings, businesses, and real estate photos, then you will need to acquire your Part 107 License, here is a link to get you started…
Since you live in Nebraska, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
However, in the meantime, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s and the Mini 3, including the User Manuals.
As for which Drone will work best for you, only you can make that choice...
Happy, Safe and Legal Droning…
Welcome to Mavic Pilots! 🙂 Enjoy the forum!Thumbswayup
Welcome to the forum! :)
I have both the Air2s and a Mini 3 Pro, I like them both for different reasons. The Air2s to me seems smoother to fly, I think that has to do with the remote. The biggest downside for me of the Air2s is the camera doesn't zoom for still pictures, it does for video however. You will have to fly it with a phone or tablet, for some that is an issue.
The Mini 3 Pro with RC is a small compact package, the RC eliminates having to hook up a phone or tablet. The built in android tablet to me is not as smooth as using an Apple device. This is most noticeable in the map of the drones location.
I would say whatever you choose go with the fly-more bundle, you will want the extra batteries and the carrying case with both should hold everything you need!
Good luck, it is a tough decision between the two!
Biggest needs.
First, you must take and pass Part 107 FAA test if your going to use your drone for income. What to buy? Depends on your budget and remember you get what you pay for. After your purchase, download the owners manual and read it cover to cover at least 3 times. You might want to spend 2 or 3 hours of flight time before you tackle camera work. If you’ve never done video, buy a book or take a class. These new drones/quad copters almost fly themselves until they don’t. Most crashes occur because of pilot error, just like small airplanes. Overconfidence is the demon.
Remember to walk before you run.
About flying over groups of people; that is illegal by FAA rules. You’ll learn that when you take your Part 107 test.
Good luck, flying these drones is a lot of fun.
Biggest needs.
The spiffy new controller is a total game changer ,I flew both just this Morning ,I will vote Mini 3 ,or better yet Air 2s and Spiffy new remote ,but DJI has to marry the first
Reactions: guywholikesgolf
How big is the sound difference between the two of them?
Additionally have you used the active track in them? I have seen things online that say they are the same and some that say they are way different. What are you thoughts?
saskia
