Help required please new user!!
Anyone in Sheffield that can, is able to help me do the video registration, as I cannot do it.
This is the link that explains how to do the video to get the coverage… If you do not have a smartphone to do the video, ask a friend, relative, neighbor, etc…
DJI
If you do nto have such a person, then try to get the coverage back and buy the coverage from your local home/apartment insurance carrier…
I am sorry, I live on the wrong side of the Atlantic to help…
Recently purchased mini pro 4
Since I cannot do your video for you, here is the next best thing. Instructins to help you keep from crashing it...
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Hiya,
Recently purchased mini pro 4, i added the Care refresh 2y, but unfortunately missed the 48 hour registration.
Thanks in advance.
You will probably find a You Tube that explains it. I did it year ago, and it was difficult until I figured it out.
nui
