Help with first entry with CP2112 and EV2400 adapter
jftman
western NY
I like being able to neatly patch the M2P battery to the EV2400 adapter which my PC happily connects with USB.
But the CP2112 is not recognized, therefor the pc can not install drivers.
I searched Silicon Labs for help but the closest I can do is install the driver updater, and of course it will cost money to update any thing it recommends.
I am not even sure the updater can see I have the CP2112 hooked up to the 2400 and it isn’t really present, no USB Joy Joy yet, so what good will buying the updater do?
I need a program for the CP2112. I have seen a bunch of youTube vids on how tge 2112 is connected and when ever I run Dji Battery Killer it never connects to the battery info routine.
At least with the adapter I can choose and hit connect, but because the 2112 hasn’t come into recognition, I am not doing well.
I even tried with a good battery, same limited results.
Can I get my 2112 onboard my win 10 PC?
Three wires, GND num 1 ,SCL, SDA all hooked to J2 on EV2400. Two separate USB cables one each to 2112 and 2400. Nice little interface connects the 2400 to a battery via ribbon cable.
At present I have no idea what the adapter does!
My sense says that Dji Battery Killer program is all I need to use the CP2112.
But in setting it does not show up to connect to it, so Poopy.
UPDATE,
I unplugged the 2112 from the J2 connector and now without the three wires from the battery via the bridge to the adapter 2400 it popped a USB connection? Any thoughts about what happened?
ricardocfln
