Hey There! New member. My Pro5 Mini is waiting at the post office for me. Never have flown a drone although have flown Rc planes.
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
First, if you have not already done so and you want to fly your drone recreationally, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). This Link is to the Pilot Institute Web Site where you can get your TRUST Certificate. (FREE…)
Since your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. This link is to the FAADroneZone where you can register your Drone. The cost is $5.00…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Washington, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Wow! Very informative! My mini5 is weighing in at 300 grams. Isn't that unusual? I guess I might have to take some extra steps.
Thanks everyone!
Welcome to the forum. We look forward to your participation and your view of the world
Reactions: Rchawks and MA2 317
Thanks everyone!
The DJI Mini 5 Pro's base weight is around 249.9g... Around is the optimal word and probably needs to be registered with the FAA ($5.00)..
But with the larger Intelligent Flight Battery Plus, the total takeoff weight pushes over 250g (closer to 290g total), meaning it often exceeds the sub-250g threshold, depending on manufacturing tolerances and the specific battery/accessories, which has significant regulatory implications. The plus battery itself adds substantial weight (around 116g) compared to the standard (around 70g), making the drone more stable but less regulation-friendly.
The only issue of it's weight is that it needs to be registered and the $5.00 gets you 3-years... Then you do it again...
Now, if yu get a Part 107 certification, then all drones you own and use under the Part 107 must be registered, even the sub-250 drones...
Any case, so have fun and learn to fly it...
Perlytes
