Hi all from Southern Oregon
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
New Pilot of a DJI Mini SE
Hi New Pilot.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
The Mini SE is a great little bird and you will have a lot of fun with it as you learn the basics. As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, so you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Happy, Safe and Legal Droning…
New Pilot of a DJI Mini SE. Starting with the basics.
Medford- fortunate to have lots of open spaces to practice in, up here in metro Puget Sound it's a real hassle, 160 miles of continuous city north to south, and the sale of No Trespassing signs does a brisk business.
Welcome to the forum, fly safe!
venoom2001
