Hi from Bishop, CA
Hi - new to the forum from Bishop. Looking forward to learning. I have a Mini 4 Pro and my interest is still photography.
Well, you live in the most photogenic place in the US so you should have a great experience filming there. I spent a solo week there (Holiday Inn) several years ago, and indeed, there is an amazing photo no matter where you look.
Dale
Miami
Welcome to the forum. I have aMini 4 Pro and a Mavic 4 Pro and I do a lot of photography especially with the M4P that I purchased when it was first released here in Canada. I also do still photography with my sl Sony camera gear. It looks like you live in a area that should have a lot of photography opportunities. I live on the south end of Vancouver Island in British Columbia with no end of photo and video shoot locations. Attached phototaken with Mavic 4 Pro, Nanaimo, British Columbia. Cheers
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). While you are using the small battery your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. But if you are usng the large battery, your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
LeoleoLeo
