Hi from Chicago Illinois
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Just got a Mavic Pro and think it would be cool to meet other fliers from the area… maybe start our own group or something.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Happy Droning…
Happy Droning…
Cool, thanks for the links. A couple places listed are right near my office, so that’s cool. I’ll have to download the manual for the mavic pro since it seems more advanced and “pro” like compared to my mini se. I have the TRUST certificate and it is registered with my mini se, awaiting the stickers from pilot institute, one of the reasons I have only tested it by basically flying around my house where the neighbors know them and I know the cops…. Stickers probably be here in a couple days.
Thanks for the acknowledgement. Good Luck with both of your drones. In case you did not have the link to the downloads for the SE, here you go...
DJI Mini SE - Download Center - DJI
And when I write, read the manuals twice, I'm not being an authoritarian, there are so many things that you can do with your drone and in most cases, the manual explains how. If it doesn't or the instructions are vague, or incomprehensible, search YouTube and you will be offered lots of videos to show you how and perhaps, even better, how not to...
LT out...
LT out...
I think I will print out both manuals, the one that came with the mini se…. Is extremely mini itself…. And I mean size wise…. Don’t know who can read it how small it is.
Looks like this mavic pro has many more features than the mini se too.
Whoo, something is wrong with the settings on your computer software, assuming that you are viewing it in Adobe Acrobat Viewer.
But, you are probably viewing it in the PDF viewer of Google. Do not print this as you cannot adjust the size.
Download the PDF from DJI onto your computer and right Click it on the file and select Open With, and select Adobe Acrobat.
In acrobat, click print and you will need to make adjustments on the Print Screen, Select FIT, under the Page Sizing and Handling… This will cause the file to size to fill an 8-1/2 by 11 inch paper.
If you do not do this, it could print on the back of a business card…
No, i was talking about the booklet that was in the box with the mini
Oh, My Bad… I just glanced at all of my Mini 2's Mini booklets and foldouts and I remember why I put them away… Read the User's Manual, it's a lot more useful than a booklet in 10 different languages that only dedicates 5-pages to any one language and only covers Disclaimers and Safety Guidelines, all of which are probably well spelled out in the 47-page manual…
artfulaltitude
