Hi from Denmark
Welcome to the forum! :)
Greetings from Vero Beach, Florida. Welcome to our forum. I'm sure you will find tons of useful information here and make a lot of new friends.
Hope to find som useful info regarding my Dji Air2...
Since you live in Denmark, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
RichardThiery
