Hi from England
Hello folks.
I've just treated myself to a pre-owned Mavic Air and I'm itching to get started.
Hopefully I don't bore everyone with incessant questions.
Cheers,
Guy
Hello from Canada. Ask away!
I've only been flying for a year, but I'm licenced in the UK, Canada and EU, and just did my TRUST exam this week, planning on doing Part 107 soon for US. Cheers!
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air, including the User Manual.
Fly On and Fly Safe…
I'll have a look round and see where I need to post my first (of many probably) question.
If you have questions, look over our site first and you'll see various sub-forums, General Discussion (good for an all around question), A1 (good for those drone specific questions…), Photos and Videos (good for those type of questions), Crash & Flyaway Assistance (for those worse case issues…).
By asking your questions in the specific areas that involve the issue gets you the greatest chance of contacting an expert in that area…
Br sure to read the User Manual, I sent you the link already, even read it twice…
Use the Search function, you will find out that any issues you have will have been experienced by other before you…
Go to YouTube and watch video on your drones reviews and how to set it up… Seeing a procedure is a whole lot easier to understand that reading about it…
Good Luck!
Welcome to the forum! :)
famagusta
