Hi from Italia!!!
Hello from the Crossroads of America albertino78.
Nice to meet you Alberto. 🤝
Glad to hear the FCC hack works for the mini 3 pro.
It's too bad the aircraft have limited abilities in different regions.
Good luck and welcome to the Forum. :cool:
Welcome to the forum. We look forward to your participation and your view of the world.
Benvenuti nel nostro forum, da Hauptmann, a Hurst, Texas! Felice di averti con noi!
Don't you love the flexibility of vantage points an aerial camera platform affords--you can get shots and videos you could only dream of before! The FCC mode will help you a lot. I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many from Italy--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy.
Rich R (aka Hauptmann)
I’m Alberto and I’ve just modded my Dji Mini 3 Pro RC
Since you live in Italia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome to the forum! :)
RichardThiery
