I’ve recently started using drones and I really enjoy this new world.
Welcome from the Hampton Roads area of Virginia, USA.  We have a Member's Map in the Upper Right of the Title Bar.  Click on "Members" and then Click on "Member's Map…"  Check it out and you might find some new flying friends.
					mavicpilots.com
Since you live in Italy, there are specific laws and rules for you to follow, please check to ensure these are current.
				Enac per il trasporto aereo del futuro: innovazione tecnologica, sostenibilità, intermodalità https://www.enac.gov.it/app/uploads/2024/04/video-home-2.mp4 Notizie in evidenza Vedi tutte le notizie Cos’è l’ENAC L’ENAC è autorità unica di regolazione tecnica, certificazione, vigilanza e controllo...
					www.enac.gov.it
You paid a lot of money for that Drone, put your phone number on it.  If your drone gets lost or stuck in a tree and it finally comes down when you are not around, give the finders an opportunity to contact you so it can be returned.
Now, for the Fun Part, But do not let the excitement of the moment get the best of you.  When you are going out to fly, do it slowly and deliberately.  Get used to a set procedure and even practice it.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…).  On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it.  I also fastened a short "Remove Before Flight" ribbon to the cover so it's more noticeable and I do not forget to remove it…
Turn on the drone and watch it come to "life."  Watching the Gimbal go through its self-check is almost like watching a puppy or kitten opening its eyes for the first time…
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right).  By now, your Controller will probably report again, "Home point Updated."
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Drone.  When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube.  Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Fly On and Fly Safe…
