Hi from Michigan.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome John from the gulf coast of Texas. I have a brother living in Gaylord. How far are you from there?
Hi, R.Cowan-- about 3 hours. I'll give you the relative coordinates by the Big Mitten technique... He is located about the last knuckle on the middle finger of a left hand, while I am closer to the first knuckle at the base of the thumb. laughing... It is a Michigan thing.
Mike
Mike
LOL...Yes, I've heard the analogy often! Welcome once again and I believe you'll find this forum helpful. Happy and safe flying. Cheers!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through… I do not know if you are a newbee, so I'll share the lot with you…
Even living in Michigan, there are a couple of Legal Things you need to do… Register your Drone; that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Reactions: Skywatcher2001
Thanks..........I have my TRUST. Have also downloaded the owner's manual. I'm going along rather slowly, and working on fluidly working the joysticks. Thanks for the advice.
mrsz
