Hi from Perth
Pterodactyl
Perth, Australia
I started a few weeks back with a DJI Mini 4K...
I now have the Mavic 4 Pro. I am self-employed and have an I.T. Business so some aspects have been very easy for me but I still have a lot to learn about the Mavic, Drones and production using Final Cut Pro.
I was going to get either the Air 3S or this but the Mavic camera and power was just a bit too tempting. I got it this week and have already done a number of flights. It is magic.
I have a PPL from years ago and flew gliders and I also love photography and have a Canon 5D3 on my desk at the moment. I must admit the iPhone is so easy to use though and is the camera you have in your pocket. The iPhone doesn't have wings and neither does the Canon but the Mavic does...I can see advantages.
Perth is a very windy city and the Mini 4K when you fly it...all too often you get wind alerts. I know it is still safe to fly by going into wind and then flying home downwind but I definitely want something with more speed and power from a practical point of view.
The Mini 4K is very impressive although the other issue was connection stability and range which is somewhat limiting although the range is still very useful.
Now my Mavic learning begins!
Greetings from Birmingham Alabama
Welcome mate. Your going to love the mavic 4. So many drones before this has enabled DJI to really refine this bird.
Flight time, stable connection, good camera system and great flight dynamics make it an amazing piece of kit.
A big welcome to the forum from the UK!
I’m very envious, what a drone to start out with 😍
I am mad...madly in love else I couldn't spend this money. I am aware too that a flying camera isn't as safe as a ground based one. I did get the AirCare Refresh package...prudent.
I did a quick flight tonight and the screen looked all washed out...then realised it was in DLog...I had no idea. It is much easier to fly and safer than the Mini 4K but obviously does a lot more from the camera point of view and it moves...fast.
Reactions: LoudThunder
Yes, what you say is exactly the truth...the constant invention and progress building on earlier designs and it will be that it will become superseded, in time, by even better designs.
It is a fantastic bird and so safe and easy to fly. I went out on a bush track on my mountain bike and flew the Mini 4K...trying to manually land it on a narrow track in wind...I guess it was bush and trees and the Mavic was too precious but flying it would have been so much easier.
I started a few weeks back with a DJI Mini 4K... I now have the Mavic 4 Pro
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to the User Manual offered by DJI for the Mini 4K
DJI does not yet list a manual for the Mavic 4 Pro…
Fly On and Fly Safe…
I look forward to reading how the Mav 4 works out for you.... my Mav 3s have been work horses for me.
Hi,
Thanks for the help and I should have another look through the manual, as suggested. I am careful to make sure that the home point is updated.
One question is where to find a good source of royalty free music as I use Final Cut Pro and I'd like to put clips to music rather than the limited 'jingles' I find in FCP.
I have flown it a lot aleady and had fun with waypoints...I found that they are great for creating smooth sequences. Hayperlapse might be next. One thing I like is I can record internally if I forget the SD card.
Amazing machine...the way it hovers into my small backyard....I let it land itself...
Cheers,
Grant
max_dji
