Hi from Shanghai
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
I do not know anything about flying a drone in Shanghai but be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all.
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro. You will also find the 74-page Mini 3 Pro's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 3 Pro - Downloads - DJI
Happy and Safe Droning…
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Birddog495
