Hi from Sherwood Forest
Welcome to the forum! :)
@twickers14 he was hoping to ,but the sheriff of Nottingham,has banned all drone flights over the city ,and the surrounding woodlands with the help of the NT, NE something about it being a SSSI
Looking forward to producing lots of vids and probably asking for a lot of advice.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Great info thanks
kyros21
