Hi From Singapore!
Hello from the Crossroads of America waihoong11.
Nice to meet you 🤝
I don't have a FLIP but I do have a NEO.
Visit the new FLIP PILOTS sister site if interested.
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama
Welcome to the forum from the beautiful woods of Maine, USA!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forums using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!
Fly safe, enjoy and stay safe!
I'm a newbie in drones.
Since you live in Singapore, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
iBeardedman
