Hi from south Sweden
Hello from the Crossroads of America ratjack.
New mini 2 pilot, 70 year's old so started late 😄
It's never too late.
I'm sure you flew a paper airplane in the past.
The first steps of a rewarding hobby. :)
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama USA, welcome to the forum!
Hey, my birth certificate says 70, but I identify as 50. So nowadays that what counts. There! All fixed. Now enjoy flying….
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Is there a word in Swedish for 'Y'all?' Just asking.
I'm not from Sweden; I grew up in "Up-State" New York State (200-miles further North…) and I now live in Virginia. I hear the locals use "Y'all" all the time. I refuse to give up my in-bred colloquial expression, "Youse Guys…" and they say, "Where are you from?"
I also have and fly the Mini 2 and love it, and I'm oldr than you… At the bottom of this I've inserted the link to all of DJI's Mini 2's downloads, including the User Manual…
Since you live in Sweden, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Welcome to the forum! :)
Reactions: old man mavic
CMDR DV TEARDROP
