Home made Landing Pads
ElMarco
So I made a landing pad for home and thought there must be others out there building their own too.. So lets see some .. Here's mine.
Night view.. I can change colors and strobe. I used the led strips and the yellow and black stripes are caution tape.
I used a piece of coroplast (corrugated plastic) 4mm thick and 26" Diameter.
On the bottom side I remove one layer right in the center so it folds easy, then I painted it, I use three small homemade pegs to fasten it to the ground.IMG_0992.JPG IMG_0994.JPG IMG_0995.JPG
I've found that the Mavic doesn't like the led strips at night., Even with avoidance turned off it drifts away from the pad.. Hmmmm
NY NICKY
