Home Point Update
howard.allum
Plettenberg Bay, South Africa
Flying a 'Track Me' mission ,and having set Maven to update the home point every 25 metres (I was walking along the beach), I got a red warning that said, 'Unable to Update Home Point' after walking about 100 metres.. The indicator in the bottom right of the screen showed that I still had a good GPS signal on my iPad so why wouldn't it update the home point? I'm sure it's something obvious but I can't think what. Any ideas?
Did you have the home point and started to fly and than moved the controller away from the area you got the original home point at. If you so you would have to manually adjust the home point on the map.
Phantomrain.org
Gear to fly in the Rain., Land on the water.
Is there, in Maven, a limit to the number of times per flight that you can update the home point or a limit to the rate at which you can update the home point etc.?
A little testing might answer those questions.
marcusjohn3684
