You have 3 main factors to consider when it comes to connectivity ... besides pointing your RC antennas up towards your drone.
1. The Mini SE uses enhanced WiFi & not Occusync ... both is WiFi but "Enhanced" is more prone to interference along the line of sight, around the RC or around where your Mini SE is flying.
2. Chosen frequency ... this is what separate 2,4 & 5,8GHz if you can chose with a Mini SE.
2.4GHz for better penetration & longer distance ... but more prone to interference & gives slower data transfer
5.8GHz for less interference & higher data rate transfers (better live view) ... but worse penetration & distance.
So if you fly where you have other interfering WiFi networks ... 5,8GHZ might get you farther out than with 2,4GHz in reality.
3. Unobstructed line of sight ... it's easy to think that flying up on 120m will guarantee a LOS free of obstacles ... but if you look at the picture below & calculate things a bit with your distances to trees & houses & their heights.
I have an example from my own condition flying out from my backyard ...
I have a tree line 210m away, that's the tallest object I see ... it's pine trees approx 35m in height. Replacing that distance to the house in the pic. with 210m & the height of the house with 35m ... that gives an angle from where I'm standing to the pine tree tops of 9,5 degrees. If I fly up on 120m (max allowed in Sweden) & fly out my drone it will theoretically start to be covered by the pine trees when it's reached out from where I am at approx. 717m.
This theoretical calculation is pretty much what I see when flying for real also, the live view starts to be choppy at that approx. 717m distance & will cut out completely just below 800m.
I have a
Mavic Air 1 ... which also have enhanced WiFi. Going to a completely flat field without any trees or other obstacles & far away from all that could interfere with the WiFi connection I have reached out 4km once when I tested ... had to turn around due to the battery noting else. So Enhanced WiFi can perform if there's no interference at all & a totally unobstructed LOS.
So consider how it looked in the pic. you attached I would say that 600m out doesn't sound unreasonable & shouldn't be limiting weighing in the VLOS regulations.
