- Joined
- Feb 4, 2017
- Messages
- 24
- Reactions
- 5
- Age
- 24
I thought I saw in the manual 20 mph somewhere but I can not find it now, I have had mine in 20 mph and been okay.Title says it all. Any of you tested it?
I've pushed 45 kph.Title says it all. Any of you tested it?
Yeah I'd agree with what's been said - DJI understate it's ability to cope with wind, but once you get over the stated value the gimbal struggles to compensate for the aircraft pitching and rolling about. I flew mine today in probably 20G30 (knots) and it was just about OK without switching to sport mode, but landing it had a high pucker-factor and I probably won't fly it in as much wind again - it's not fun and just asking for an expensive mishap.
I am curious how did you establish this as the wind strength you were flying in?..I was flying in....sustained winds of 35+ miles per hour with gusts up to 60 miles per hour (95 kph)...
I see elsewhere you are in the slow to update schoolView attachment 8919
I took mine out today to chase some boats on the river the wind was around 18-20 mph, against the wind I did 30mph, against the wind, I hit 53.6 mph with the wind!
the latest Go 4 app gives me problems I uninstalled it and im using the original go app 3.7 build. Even if the mph is off, my mavic still preformed better against the wind then when I used the Go 4 app. If you have obstacle avoidance off the speeds improve. I had mine off.I see elsewhere you are in the slow to update school
"I said before that you should wait to do firmware updates,"
Are you on the latest Go4 Android build?
If you are still on a older android build, your max speed is likely incorrect due the fps mph bug. In any case any speeds over about 70kmh/44mph, should be very short lived as the FCC throttles things back to a maximum GS.
Yeah no worries.
The correct speed would most likely show in healthy drones otherwise multiple your mph by .68. Also the speed on the RC will be correct. good thing is when you do eventually update your Go version the speed will correct themselves.
Have had mine up in wind strengths of 48km/h as measured by healthy drones and trying to fly flat out sport mode, downwind has only achieved 76km/h. This was probably effectively an overspeed in any case and would have been short lived as it throttled back. Actually just checked the log and it was only at that speed for ~ 1.5 seconds then it slowed back to 70km/h or 43mp/h which I gather is the speed to which it is governed
Yeah we are digressing but some of their stuff (battery amongst others) has yet to be mavic optimised. Their Ground speeds should be right as it directly from your log without the Go conversion error. Wind if anything will be conservative and under read. I do know that when flying mine in 48km/h winds it was drifting away at >15 km/h in the hover and it would have been gone in a minute or two without input. Sports mode was making slow progress upwind. This type of flying requires careful pre planning. This is why I call BS and Question conditions gusting 90 km/h as being flyable.Im skeptical of healthydrones with my mavic. It claims i never have good signal but i have always had full bars and never lost signal.
