How often do you use your gimbal cover?
I only use mine when taking long trips either by car or by plane. For just short rides close to home, I don't use the cover; I just brace the gimbal against a pillow to keep it from vibrating. What about you? https://superbearadventureapk.net/
I use mine similarly, but I'll try your pillow trick for local rides. For flights, I always use the hard case with foam inserts for maximum protection.
I have the Air3s as the very first drone that I owned or flew. I also found the cover to be fiddly to put on, but thought that it was important to protect the most delicate part of the drone. However, after a recommendation on this forum, I purchased a new cover on AliExpress ($5), that is MUCH simpler to fit, and gives better protection IMO.
Strongly recommended, it is trivial to fit.
Protects both the gimbal and the front sensors, and clips onto the bottom of the body. I have found the BRDRC stuff to be pretty good, but this was a 'best buy' for sure.
I also enjoy their 'dropper' that activates using the downlight on the Air3s, much fun delivering items :-)
Reactions: Rchawks
d-dot27
