How to I display the half circle with drone location at the bottom of my screen
skered53-464
Oregon, USA
I did updates today, so I should be GTG as far as firmware.... Also I saw a video of the small map be swapped to a sight showing an artificial horizon, how do I turn that on ?.
Since I have this issue on the Mini 2 and Air 2, I figured I'd post it here vs in 2 separate sections.
Thanks, Derek
If I am understanding correctly? This:
Thanks, Derek
"The half circle with location of drone at the bottom of your screen" was replaced a long time ago with the attitude and location indicator shown above in post #2. Even that indicator has been recently modified in that there is a button in the upper left corner of the indicator that will change the center from being either locked to the drone to the center being the homepoint (like the Go4 app always has been).
Reactions: maggior
