how to install netflix bt300
You have to download the Netflix apk file. Put it on an sd card and install from that. You will have to check the box that allows installations from unknown locations under the security menu.
I don’t think it matters what version you install. If your first installation doesn’t work you can always uninstall then install an older version.
tried from apkpure it did say it does not support my device, can you share which version u installed
Bandar200718
