Howdy
Welcome to the forum @zone! :)
Welcome to our forum!
Lots of great stuff to shoot in Utah, especially Southern Utah. Too bad about Bryce and Zion being US Nat'l parks, though. Drone flying there is a big time no-no.
Thanks. Lot's of other stuff around. Basically every where you look is stunning. We're about 15 minutes from the North entrance of Zion (Kolob Canyon).
New member from Southern Utah. Somewhat familiar with drones. My last job before retirement was developing a handheld anit-drone device for military and law enforcement.
As a New Drone Pilot, whose job is now to have fun with them rather than Blowing Them Up… there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Utah, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum!
Reactions: zone and Hauptmann
Welcome to the forum from NW Montana
robygilbert
