I’ve tested the PGYTECH Mavic 2 Pro ND8, ND16, ND32 and ND64 filters set
karlo_m
Hello guys! For the past few weeks I’ve been testing the PGYTECH Mavic 2 Pro ND filters set and I’m sharing my results with you!
The first thing I did was test how correctly do they stop down the brightness. They should stop down the brightness by 3, 4, 5 and 6 stops. Ans that’s how I tested them! In the image below you can see that each photo is exposed perfectly which means that the ND filters expose everything perfectly!
Then what I did was, I took a 4K HQ clip with each filter and without the filter to see the difference in the sharpness. And I was very pleased that there was none!
I’m pretty happy my money was well invested since the filters don’t come that cheap!
Hope you’ll find this useful! :)
Reactions: robzab and inverted
I have the same set.
I have noticed that ND16 and ND64 are a bit loose on the camera
They have just a little play when attached
I'm not sure if that could ruin a photo or a video in flight
diilmarcin4
