Image Artifacts
Hello and welcome to the forum. Could be the memory card, memory card reader. Have you tried to take a photo to the internal memory instead of the card and see if you still have the same results?
Reactions: Thomas B
Thanks for the welcome. I have not tried the internal memory. I will.
Hello, the SanDisk 256GB Extreme microSD on the Mavic Air 2 in normal flight mode. Thank you.
The artifact only happened on the one photo. Maybe a one-off glitch. My take away is to take more than one photo. Even if you think you got it.
Your solution/ work around is what I do... always 2 or more stills of any subject.
Hope that works for you.
Someone mentioned a new card reader. I have had similar bars on other cards and tried a new reader and they were gone.
Could be the connection between the camera and it’s control circuitry. Loose/broken cable connection.
dvkhamtruocsinh
