Interesting RTH Routine.
grahamjohnson10
Today I actually managed to get a flight in between the crappy weather here in the UK.
I wanted to understand what happens when I initiated RTH, and after visually and then analyzing the flight log was surprised what I found.
1) Hit RTH button
2) Preassend MM didn't change it's heading but rises 4.5 M
3) The MM rotates and aligns with the home point
4) Increases altitude to RTH height setting
5) Flies at P mode speed to above the home point.
You should know that without flight data. Why were you surprised? Posting about what you learned is not the way to learn flight data.
Reactions: grahamjohnson10
Yes your totally correct, maybe the best thing I learnt is reading the flight logs and eventually helping less experienced pilots out.
Hangar Drones
