- Joined
- Sep 3, 2017
- Messages
- 40
- Reactions
- 11
- Age
- 44
Try as follows, fully reset the CrystalSky and make sure it’s on the latest firmware.
To factory reset by going into Settings, Backup & Reset, Factory Data Reset then clicking Reset Device.
2: When it reboots reconnect CrystalSky to your wifi network (you will need to put the password in again) then go into Setting, then Update and click Check For Updates, t
connect a fully charged main battery then put it into standby for 12 hours, not shut down but just in standby. Then fully reboot and see how it is.
If this does not work then it may be a bad internal battery or charge circuit.
So how should this work ??? Should the screen stay on when you remove the battery and then run from the internal battery until you plug another battery in ??Hi.
Testing the supposedly hot swap of the battery for CS 5.5 today, I have verified that it always turns off when the external battery is removed, and the internal does not keep the CS in suspension.
The status of the internal battery is unknown. Any ideas?
Thanks!View attachment 22897
Not working, I could not prove it. From what I read, when you remove the battery, the screen goes off but the CrystalSky continues operate with the internal battery until you insert a charged external battery, then the screen will turn on again.
