iPad 4 Mini, special cord needed?
DSGDSG
As my mavic is not yet here, I'm unsure exactly what I am working with. I ordered a 32gb cellular ipad 4 mini refurb today and I'm wondering if whatever cables come with the mavic will suffice to connect it with the controller or do I also need to order a longer/special cable to use it properly?
Thanks.
You're going to need a longer Lightning cable. You could use the cable that you're using to charge your iPad or here are a few shorter cables that'll work:
  • DJI (10" 90 degree cable)
  • Griffin (11.5" 90 degree cable)
  • Anker (12" straight cable)
  • Cambond (12" straight cable)
  • Kanex (8" 90 degree cable)
Thank you for the help. So just any standard lightning cable will do? My charging cable is 6' so I'll have to order something shorter.
Reactions: Rbruz
Yes.
K, I'm a firm believer in back scratching. Thanks for the help, I'll order now.
Actually, can you please give me a link for the grey on the anker? Yours goes to the white right now and I want the gray but when I click it your affiliate disappears. Thanks.
**Update** I wanted this for Sunday so time was a factor and I ordered. I believe I was able to create a working affiliate link for the grey with credit to you by looking at the one for the white. Hopefully you get the credit.
wkyang
