ipad
eigenflight
Monument, CO, USA
I am trying to connect the Mavic Pro to an Ipad Pro 5th generation. This one uses a USB-C connector instead of a lightening connector. It will not recognize DJI Go 4 will not recognize the Mavic Pro. I tried various adaptors and even got a couple of "DJI approved" "micro to USB-C cable, neither of which worked either. Is the Mavic Pro fundamentally incompatible with the Ipad Pro?
Reactions: Bob in Savannah
I didn't think it was. I'm assuming you sideloaded the app from dji directly, right? Also, I did read that some earlier Apple products aren't working.. Someone will definitely chime in shortly and clear up which ipads work and which ones don't. Good luck
A to C connected to the RC's bottom port (remove the side connector) should work...
I have a mini6 connected to the latest version of the GO4 app. I use the USB 1 (rectangular connection) at the bottom of the controller and USB C to the iPad. The side connector does not work.
MrUlqinaku
