Hi,
I just received the DJI goggles and I still need to do a proper flight. Testing them at home I've tried to manually set the IPD. I know I have 62.5mm of IPD but the headset itself doesn't seem to show the ipd value I've set. How do you set it? What is the result you try to achieve? Setting a wide ipd I seem to have a closer, and smaller screen. Putting the lenses closer it seems a bit more bigger...but further.. There is also a fatigue feeling in some of these ipd settings.. (like when the lenses are in the closest position).
Sometime I also see some reflections in the middle, top and bottom, especially when the background is black. Also on the edges some time I see some reflections and little lights. Maybe I didn't fit them well on my head?
Anyone experiencing these things?
Thanks
Thanks
