Italy Suspected flyaway
Fabrizio
Ciao, today I was flying with my Mavic and after the take off and few meters away, started to rise altitude by himself without touching the commands, about 15 meters, than I thought the was a flyaway and I pull down the right stick and started the auto landing, this happened 3 times, and I was scare to crash the Mavic on the stones, then I give up... anyone had similar experiences? Thanks
Can we take a look at your TXT flight log? If so, please upload it here and post a link back here.
Reactions: marg2
You can find instructions at my link above.
msinger, it will take time, I have to sincronize 100gb of my iphone to itunes and now is 4 in the morning here in Rome, if you don't mind I will do it tomorrow, and I will message you again... thank you so much fir your help!
No problem. We can work on this tomorrow :)
At 1m 27s in your flight log, the downward sensors were detecting the ground was less than 0.5 meters away. That was causing your Mavic to auto ascend to get above the 0.5 meter level where it always hovers before landing on the ground.
At 1m 39s in your flight log, you moved the throttle to the full down position. Since the downward sensors were still detecting the ground was less than 0.5 meters away, that caused the Mavic to switch to forced landing mode.
You can prevent both of these issues from occurring by disabling the "Landing Protection" setting in DJI GO. That's the best available workaround at this time.
Thank you so much, I suspected too looking in some other blogs, I will try to disable landing protection and I will see if it works... you are my hero, really appreciate your efforts to help me...
Fabrizio planing my Italy trip will like to take my mavic and fly Tuscani how legal will be for usa tourist
Thanks
Mariano
Thanks
Mariano
Hi, if you flight just for fun and not for work, you can go in the country side fare from people and buildings. Max distance from you 200m and max altitude 70. If you come to work you need a sort of pilot licenze...
For fun thanks
LeoleoLeo
