Joining the skies from Virginia
skycrab
United States
Hello all!
My name is Tim, I had a drone many years ago when they first came out but I'm returning to the skies in a DJI Mini 4 Pro. Absolutely love it! Learning all the rules and regulations now to keep the skies safe for everyone and obtain my Remote Pilot Certificate. Currently focusing on learning about flying over people and trying to make sure I've got everything right by sticking to the book. (Although some parts can seem a bit vague) Found the thread here regarding OOP and it's been most helpful! Hoping to do some aerial photography as a side business. Any tips or pointers greatly appreciated!
Happy and safe flights!
THings have changed since you were a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Virginia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Welcome to the forums from the bowels of California!
Welcome to the forum from the beautiful woods of Maine!
Reactions: MA2 317
Hello all!
Reactions: wjkrysak
Mamanov Ramazan
