Jump video Gimbal
Xblog
Hi,
i've noticed a jump video sometimes... (see video : 3' and 11') Do you have any idea of this problem ?
Thanks you so much !
Not about the jumpiness, but can get rid of that jello effect with an ND filter.
Only 12 flights (total 1,5 h) .. l've just do calibrate gimbal, i will test tomorrow. Thanks!
an user here, have the same problem...
i contact dji support and they suggest that i send it to us for repair and analysis.
Hi, I had the same problem when i received my drone, here is how i solved it:
  1. Re-install the Firmware using DJI Assistant [How To Video]
  2. Do IMU calibration using the DJI Go App [How To Video]
  3. Do Gimbal calibration using the DJI Go App [Just Press calibrate in Gimbal Settings]
Hope it helps you.
[I higly suggest you to buy the DJI Care Refresh Warranty]
Hope it helps you.
Thanks ! but dji said i have a problem with gimbal...
CMDR DV TEARDROP
