Latest update?????
Mycallhill
London uk
I have just updated latest firmware;before updating I had low light and only 4 satellite s but let me take off;;then I did latest update now I can not take off;is this purely due to less than 8 satellites or a combination of low light and less than 8 satellites;;can I override satellites if I need to take off?;thanks Mick h
May I suggest you read the release notes for the firmware update?
Overview:
  • Date: 2019.12.31
  • Aircraft Firmware: v01.00.0400
  • Remote Controller: v01.00.0400
  • DJI Fly App iOS: V1.0.4
  • DJI Fly App Android: V1.0.4
What’s New?
  • Added feature to unlock GEO zones (requires DJI Fly v1.0.4 or later).
  • Added feature that disables takeoff when the GPS signal is weak (GPS <8) and the environment light is not sufficient. This feature can be disabled manually (requires DJI Fly v1.0.4 or later).
  • Added requirement for compass calibration before takeoff when the environment light is not sufficient and the compass experiences interference.
  • Adjusted flight altitude and distance in payload mode.
  • Added warning prompt for battery cycles.
  • Reduced noise during self-diagnostics after powering on.
  • Fixed issue: linking was abnormal in some regions.
Notes:
  • Note that the update may reset various main controller settings, such as the RTH altitude and the maximum flight distance, to default settings. Before updating, take note of your preferred DJI Fly settings, and readjust them after the update.
  • If the update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 for Mavic, and retry.
Reactions: Shawnp53
robertrfletcher
