Leave filters on?
I do the gimbal cover still fits and I don't like to handle my filters any more that needed...
I have a week out until the vivids come in. If the threads are so fine on the little cap, makes sense to leave the nds on. As long as gimbal cover fits.
The filters are press on. No threads. I remove mine to eliminate the possibility of condensation between the lens and the filter, to avoid corrosion, and because I'll usually use a different filter the next time :confused:. Just seems to work out that way.
This is for the Mavic air. The filters on it are thread on. The Mavic Pro is press on
I leave mine on mainly because the weather is pretty constant at the moment
anyone leave them on while storing?
If you're going to use the same filter the next time you fly, there's no reason to remove it.
I leave my cineseries polapro 8 nd/pl on all the time and change if the lighting requires something else. (MPP)
Yep, just leave them on. Generally the last one I flew with stays on, else UV, I want the camera lens protected at all times.
Interceptor650
