Linking
AirScooter
Winston-Salem, NC USA
As a very new pilot I am confused about the use of the "Linking Button".
I am watch the tutorials and it seems whenever there is a binding process going on between the RC Controller and the Craft the linking button is being pushed.
Am I interpreting that instruction correctly or is the "Linking" process a one time mandate?
Thanks
AirScooter
Reactions: old man mavic
Your aircraft and remote are already linked from the factory when you get it. The only reason to re-link is if you are changing remotes, or binding a new or replaced aircraft to an older remote.
Thanks
AirScooter
the controller and drone link automatically when they are both started the linking button is for if they should become unlinked for some reason or if you change to another controller
Sorry for the delay with my reply.
Thank you.
This will be a new drone controller connection. So I will use the Link button for the initial binding.Thanks again.
AirScooter
Winston-Salem NC
SURV69
