Litchi left a gap.
8BitMavics
So tried out portrait orientation today and out of coincidence (perhaps), there is a gap. I haven't tried to manually key the images so maybe it's just an Autopano software issue :) Still, the auto detection hasn't failed be until today.
I wonder if compensating for windy conditions could move the gimbal to its limits and miss some pixels?
I'm wondering if portrait mode needs to have more stability than landscape -- which makes sense. I did a Hangar 360 which captured ok. It was a bit windy though, but not enough to trigger the high wind warning.
What's the advantage of taking a pano in portrait? What settings do you use for a portrait pano in Litchi?
If you are shooting your panoramas with the Litchi pano mode, you might want to consider putting your camera into portrait mode. This will give you a better row height, you will need fewer rows, and the panoramas will blend better. You will need to shoot more images per row. You can tweak Litchi to find the best number.
Here's a panorama from my Mavic, and two more - - Art from the Air - -
sscott062
