Litchi won't let me fly past 100' after .900 update
BuyANet
So yesterday I updated the FW using DJI Assistant and it updated to .900. Today I went to fly using litchi and it says Max Altitude reached at 100 feet in the air. Max Altitude in settings is set at 152 meters.
Flying with DJI GO 4 app works just fine without a max altitude so I am thinking it has something to do with that stupid authentication thing.
How can I get Litchi to fly without restrictions again? Can't even run a waypoint ....
Thanks!
Make sure beginner mode isn't activated.
Is there even a beginner mode in Litchi? It won't go over 98 feet to be exact, so I am thinking it has to do with the "can't fly over a 30m height and 50m distance" thing.
Check the setting in the DJI app, I believe it's one of those settings that persists into other apps?
Reactions: BuyANet
Oh actually I think you are right you will have to authorize the bird in DJI App before launching litchi. That will be true until litchi updates to the 4.1 api.
Reactions: BuyANet
Thought it did that by itself since it flies just fine using the DJI Go App? Ill check if I am logged in and all that good stuff here shortly after the phone charges a bit.
Yeah you will have to just launch the DJI Go app first, it will unlock the mavic then you are good to go for litchi.
Thought I did that earlier but I guess I didn't go back to Litchi. Opened DJI Go App, made sure I am signed in. Clicked on Go Fly. Then I hard closed it and opened Litchi, no issues.
Thanks!!!
Livermore
