Litchi
Hayabusa
in the past on my P3s, i typically used Litchi especially for missions and fpv goggles. Today I decided to try with the Mavic. Have the app on my iPhone, hooked up via same large USB port on bottom of controller. Only to say disconnected and had no camera view. It was reading the ac but no camera.
Any thoughts at what Im doing wrong- this time? Lol
I use the same configuration with no problem. Check with a different USB cable
I downloaded app, set all my parameters as usual. I don’t think there is anything else.
One thing I couldn’t do was add the app on my Asus tab which I regularly use for the Mavic.
I use litchi regularly with my iPhone with no problem. The only thing I can think of is to change the cable or to delete and download litchi again.
Shielded cable nowvwhich works with Go4 and downloading added app again and still same issue. Disconnected and no live feed. It shows it’s connected as you can make adjustments to camera etc... just can’t see them. Lol
Any other suggestions?
Thanks in advance
Mike
Go into phone, settings, apps and find Go4. Clear the 'defaults' tab, then try again with Litchi.
I’m really bad with this tech stuff- really bad!
I have an iPhone 7. I went to settings/Djigo4 app but do not see anything that says default.
Mike
Mike
Aww sorry, I wrongly assumed Android. Basically you want to remove Go4's permissions to use the USB, thats what I was trying to do.
I will look at it again. But if it’s sort of comunicating with it. I’m in the Litchi app/screen, it shows all statistics, if you move the dials it shows on screen, just no camera feed.
Mike
Uninstall Go4, try Litchi and if that works, reinstall Go4?
I deleted go4 and now Litchi works but only through the small usb on side. No camera from large usb on bottom.
Mije
You do realise that you need to remove the side one totally if using the bottom one?
Yes it’s removed. Bottom one works off Go4 on both android and Apple. Just not Litchi.
If same cable used fir Go4 works,then it can’t be the cable?
I remember having issues with
My asus tab not connecting through bottom. I can’t remember how I fixed it or if it fixed itself.
Mike
ironwingstudios
