Problem? Mavic Air loosing most of the maneuverability (most without loosing video signal) and even the gimbal tilts and turns to weird positions
Was unit in a crash? never, 5 month old, medium use (around 8 charges on each of the 3 batteries)
What have you tried so far? Update to the last firmware
What device are you using ? iphone 6s
What firmware are you running ? last version on all
What Go app version are you using? Last one
Any modification? no
Did you change anything or install any apps? no
Do you have a video or pictures of the problem?
All videos I tried to sinc the DJI GO 4 Flight Record with the actual footage from de MicroSD:
1º problem noticed: lost signal (wi-fi area) but the aircraft goes way from recorded home point (microSD footage shows) and a few seconds later it comes towards Home point:
2º problem noticed: didn't loose control but the aircraft seems to start moving by itself and rotates and drifts. Some strong commands are from me panicking to bring it closer, but others are very strong corrections its doing all by itself:
3° problem noticed (today): Almost losing control due to its "strong wish" to go somewhere else... many gimbal tilts and correction moves. It mays seems the video is out of sync betwen the flight records and the footage, but in the end all is perfect (when I get control back). This time I even got a "Motor Current Error. Check your propellers and fly with caution". I believe it's from all those turns and aceleratiojn it was doing by itself + me trying to corret:
I emailed DJI suport to register what's happening, but I'm felling it has a faulty compass or something.. and it seems it's getting worse :/ Sorry my english
