Lost drone: possible crash due to lost signal?
fharrihill
South Australia
Hi everyone
I fly a DJI Mavic air 2 for work, and I don't know much about it apart from using pre-set flight paths and taking panoramic photos from set waypoints.
I was flying today using Litchi on a Samsung Galaxy tablet when I suddenly lost signal. I wasn’t flying far or in a range-challenging situation, so I don’t believe this was a simple out-of-range issue. I was unable to reconnect, and the drone never returned. The area where the drone launched is a dry floodplain that's quite open with only small shrubs scattered around, but where the drone was flying towards (about 200m from the home point) there are several large trees and thick shrubs. At the point where the drone had lost connection it was out of my eyesight and I couldn't hear it flying.
I’ve since:
  • Retrieved the flight log from Litchi
  • Uploaded it to PhantomHelp and reviewed the map
  • Thoroughly searched the area around the last recorded connection point (as well as we could between the shrubs)
Unfortunately, no luck so far.
At this point, I’m trying to understand:
  • How far beyond the last recorded point the drone may realistically have traveled
  • Whether there are common failure modes (battery, GPS, failsafe behavior, etc.) that could explain continued flight or drift after signal loss
  • Any additional recovery strategies I might not be thinking of
Also, I'm not sure if this is connected to my issue but before the flight began I had an error message on the Litchi screen ("Failed in initializing flight simulator. Try again") which was preventing me from launching the drone, so I restarted the app and the error was gone
If anyone is willing to take a look or offer general guidance, I’d really appreciate it. At this point I'm guessing even if I find the drone it will be broken, so we are looking into a replacement.
Thanks in advance for any help or insight.
Drones don't crash due to losing signal.
But crashing or losing power would show on the screen as losing signal.
If your drone was well above the vegetation, it probably didn't crash.
I’ve since:
Please post a link for the Phantomhelp report
On losing signal your drone would continue the Litchi waypoint mission if you have that option selected in settings.
If not It should return to home.
That it didn't return suggests that stopped flying somewhere along the route.
Thanks for your quick reply!
Here is the Phantomhelp report DJI Flight Log Viewer - PhantomHelp.com
I did look for the drone at the end point of the waypoint mission. Unfortunately a lot of the route isn't accessible to search because of dense vegetation. The settings are set to 'hover' if connection is lost. Please let me know if there are other possibilities to where it may have landed! Thanks :)
finekio
