Lost forward sensors after rebuild
g1ant
I repaired a crashed Mavic Pro quite successfully. The plastic air grill had also taken a bash from the gimbal being pushed back into it. This made the new fan noisy as the air grill caught on the fan so I decided on a middle shell replacement.
Its a fiddly swap out soldering the front legs off but a reasonably straighforward operation otherwise.
Once I had everything put back together I have a complete failure of forward sensors. If I try to calibrate them on a pc there’s no signal from the sensors so no blue box on the screen.
I have double checked the ribbon cables on top of the gimbal and they look ok.
Is there anything else I should look for?
Ow. Sorry I cant help you but that would crush me if after I got done doing all that and it showed a bunch of errors. Hope you get it figured out!
i had the same happen to me but kept trying and finally got the sensor ribbons correct four maybe five times good luck
Newmin
