Hi All!
I am a 99.9% Mac guy (so that might have something to do with all this - lol).
Anyway I went and did a paid shoot (stills) popped out SD card, put in reader on my Mac Pro and wouldn't mount. Did a few time and finally did and nothing.
Checked Internal, and SC nothing. Used software to check SD card and recovered some, but no photo files.
Put back into drone and connected to controller and required a firmware update, did that and it seemed to reformat the SD card so def didn't get anything after that with the recovery software.
It was a new SD card (and I did not format initially in the drone) which may or may not be the issue. I am having Amazon swap it out for me JIC.
So they photos are 100% gone and moving on....
Going forward I'd like some advice on best practices and settings to double check (the SC confused me initially about the Internal / External SD popups, etc. And everywher eon the Controller when it refereds to storage and not 100% sure if it is only referring to the SC internal and SD card and/or the M2P internal and SD Card.
1 - Going forward I am going to reformat each SD Card in drone prior. Is the best/easiest place to do this is in DJI Go 4 under the Camera settings?
I'm thinking all the other locations on the SC might be referring to the SC Internal and SD Storage.
2 - So I guess I need to figure out all the software locations that refer to Storage and which are referring to SC via M2P.
3 - What are the settings in these various locations should double check to make sure everything is setup for maximum reliability (redundancy would be nice!)
4 - What/how can I double check to make sure my photos (and video) that I am currently taking are being written to the SD Card in flight.
The little ">" Play button on the lower right?
5 - Is there a way to save the high resolution photos/videos or backup what is on the M2P Internal or SD to the SC storage?
6 - I wonder if using the M2P internal storage is more reliable and then somehow quickly/easily downloading it or back it up in between filights/batteries?
Worst case I am going to swap SD cards per flight/battery JIC. But I typically do different angles/locations so that really wont help 100%. So I kinda need the most reliable way per flight possible.
As I mentioned I am all Mac so I have read about possible corruption when putting SD card into a reader on the mac. Wonder what else I can use (maybe purchase an android based tablet to use for backing up/storing and possible bonus of a client in flight viewer?)
Anyway sorry for all the questions, as it seems there are a few related issue to this.
Thank you all for taking a look at this!
Geo
Geo
