M200 rotation joy stick faulty
jarret!hotshot
the left joy stick for my m200 remote controller will only cause my drone to ascend and decsend and will not make it rotate is this a faulty remote , or did I set up something wrong?
- Try first to calibrate the RC.
- If you altered some settings, try to revert them
- Try to downgrade the firmware - then update to newest version.
You can check the stick movement in the EXP settings of the RC.
To exclude a faulty RC, try this next:
There is a yellow dot, which centers in the X/Y axis of the settings.
The dot must move in realtime as you push the rudder (left) stick left/right as shown below:
Keule, now it rotates but very slowly ten times slower than it ascends descends or moves forward,backward,left, and right.
Thanks.
jaffer1
