M2Z - 2 Questions
Papa Tom
Hope someone can help me here. I’m going from a P4P to the M2Z so I’m not entirely new to drones.
1. The micro USB connector does not work with my iPhone 6s but if I disconnect it and use the standard USB port it works fine. Any ideas?
2. On my P4P, I could tell my batteries to start self discharging after xx number of days. Am I overlooking something or is this option not available on M2
Thank you.
Tom
The cable is likely either not fully plugged in or it's damaged and needs to be replaced.
That setting cannot be changed when flying the M2. It's hard coded to 10 days.
Thank you for responding. I thought the cable might be bad but wanted to check before I started looking for a new one.
Thanks again
tortoide
