M3P lowest fixed speed in C-Mode
TTP
Sweden
EASA allows 3 m / second as the maximum speed in what is called "low speed mode" can you set this in any parameter in RC?
the only way to control the speed of the drone ,is by the sticks ,that 3 m/second ,refers to the new C classified drones ,that will have a switch on the RC that will prevent the drone from going any faster than that ,its very similar to tripod mode on my MPP which can be set from the app screen
in fact i do believe it is even slower than the speed you quoted
Reactions: TTP
There is a work around for turning CINE MODE into a TRIPOD MODE. Not sure if this is what you want but there are "Rocker Speed Controller" adapters for clipping on your FC sticks that can fine tune the stick movement down to a very slow speed, almost like cruise control. They ain't cheap! Almost $60 cdn on Amazon. Think I'll try and 3D print something.
Here's a YouTube review on them from 3 weeks ago by Phillip Skraba.
Reactions: Maikel100 and TTP
My M2P have speed of 1,2 to 1,7 m / s, perfekt speed, you ar in controll.
Phillip Skrapa's additional equipment for ordinary joysticks seems to solve the problem, the question is whether you get it approved according to future rules. But on the other hand, limiting drone speed is an FW issue so it should be possible to fix it.
I am waiting for these Scotty Makes Stuff Cine sticks - look a bit beefy but could be a cool way to get smoother shots. They appear to 'work'...
Reactions: Torque and TTP
fisterc
