MA abruptly stops after slow forward/backward movement
TorChamp
MA FW: 01.00.0400.
Even after slow movement forward/backward, the MA stops abruptly.
Can this be smooth out with some configuration settings?
Adjust the brake value in settings > advanced > sensitivity. The default is, I think, 130. If you set it lower, braking will be more gradual.
Reactions: Prospero
Alternatively, you could use Cinematic Mode to make the quad accelerate and decelerate more smoothly as well without changing the settings.
Be aware of course that by setting a slower stopping speed or using Cinematic Mode, that the quad takes longer to halt, thus increasing the breaking distance. I'd recommend trying a few emergency brakes in the wide open to see how it responds before doing any tight maneuvers.
Jrwooley4
